64 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> temporary dimensions disappeared
Wed, Apr 25, 2012 at 12:35:23 AM | temporary dimensions disappeared
kwilfong1
The temporary dimensions settings have somehow been altered, and now when placing a component, etc., I no longer see any temporary dimensions. I haven't yet found an option where they can be turned off, only options to change from where they're measuring (wall face, centerline, etc.). Does anyone have a solution? I'm using Revit Architecture 2012.
Wed, Apr 25, 2012 at 8:14:52 AM | temporary dimensions disappeared
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe that you can turn off temporary dimensions.  The only thing you can do is change the appearance under options; graphics tab.
So when you click on your component you are still getting the options to change where they are measuring from in the option bar?  If so that would mean that Revit is still reading the dimensions.. does this happen with everything in your Revit model or just a specific component?
If you are picking on multiple components temporary dimensions will not display.
Wed, Apr 25, 2012 at 10:37:52 AM | temporary dimensions disappeared
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
There are a few settings in the Options dialog box but doesn't let you turn them off.
Might be worth playing with however.
Wed, Jul 1, 2009 at 10:50:51 AM
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:21 PM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:11 AM
temporary dimensions require me to pan to see them
Sat, Mar 26, 2016 at 9:52:42 AM
Mon, Jun 30, 2014 at 9:57:48 AM
Page generation time: 0.3103
