Forums >> Revit Structure >> Technical Support >> Definition Between Existing & New Topo Surfaces
3 Posts No Rating |
Hello
I have an existing topo surface and a proposed topo surface, the proposed has building pads cut outs in it and I have redistributed the cut as fill in several areas.
I am having quite a bit of trouble defining on plan or 3D view where the redistributed fill is and it's extent. I can see the difference in secion view but can't seem to define that line or extent of surface via a surface pattern.
I have tried defining different overides in graphics and phases.
Any help please
Did you try using a different material, fill and/or surface pattern?
3 Posts No Rating |
Yes, I've tried using different materials, that helps a little but still doesn't give a defined line between the 2 surfaces, Revit will not let you assign a surface patern to a topo surface which is the real stumbling block.
3 Posts No Rating |
57 Posts No Rating |
I may not have understood all of the steps you have taken and the things you have tried, but I looked at a way to show contrasting regions of topography in a single phase (no existing vs. new).
If you use a subregion, a visible line marks the transition from the main topo surface and the subregion you have defined. The line shows up in plan and 3D views. I think the attached image shows may show some of what you were hoping to accomplish - as a manual work around.
It would be a manual work around.... defining a subregion just beyond the perimeter of your new topo surfaces and then assigning the same material to your subregion as your new topo surface....
think it - build it |
Topo surfaces, |
Mon, May 12, 2008 at 4:33:52 PM
Topo surface/Building Pad problems b/w Existing and New Construction phases |
Sun, Feb 6, 2011 at 12:28:27 AM
Rendered materials on topo surfaces |
Thu, Jun 15, 2006 at 8:46:47 AM
Existing Topo Render and Appear as Grey |
Fri, Nov 2, 2007 at 6:12:52 PM
Topo surfaces on top of structures |
Sun, May 4, 2008 at 4:59:38 AM
Members: | 2115752 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
