65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Fill Pattern not show up when print
55 Posts No Rating |
I've search the forum, and found similar question in this thread, but no one give any comments in that thread.
So, is there any way to show the Fill Pattern? If I create a small building and use this Fill Pattern, it show nice.. but in my project with a large scale building, the filled region contain this fill pattern is blank.
I'm using Revit Architecture 2012, I'm creating Fill Pattern for Vent Block (Attached).
Thank you in advance.
If the pattern prints black, then it is too intense for the scale of the view being printed.
Hmmm... that might be the problem.. when I put 10 at import scale when I use pat file.. the fill pattern can be seen without thin lines activated..
That's strange.. because I already made the pat file in the right units (mm)
Thank you WWHub.. I'll try and error again with the fill pattern and the import scale..
Fill pattern not showing up in print |
Tue, May 1, 2012 at 11:20:14 AM
How Do I Make My Fill Pattern Show In 3D View |
Tue, Jan 13, 2009 at 2:35:22 PM
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:36 AM
fill pattern and line style |
Thu, May 5, 2005 at 6:25:07 PM
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
