51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stray room speration line from level above appear in floor plan view
Mon, Apr 23, 2012 at 3:00:36 PM | Stray room speration line from level above appear in floor plan view
PaulM3357
I hope someone can provide suggestion on resolving this problem that I'm having:
Room separation line from floor above is showing up in floor plan view. These room separation lines belong in a group inside the project file. Only room separation line from the group are seen in the floor plan. Walls and other entity inside the group are not show.  View range setting did not include any level above.
Any comments or suggestions will be appreciated.
Edited on: Mon, Apr 23, 2012 at 3:02:36 PM
Mon, Apr 23, 2012 at 3:38:40 PM | Stray room speration line from level above appear in floor plan view
Your group is probably placed too low.  Check it out in section view.  Look for the group origin.
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Level Consraint on a room.
Thu, Jul 30, 2009 at 1:52:00 AM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Room Tag not visible using Plan Region? RAC 2009
Wed, Aug 19, 2009 at 12:26:44 AM
TAG ROOM SELECTING ROOM TAG IN FLOOR BELOW
Fri, May 1, 2015 at 8:24:47 AM
Page generation time: 1.8940
