61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> copy rotate and repeat command
89 Posts No Rating |
hi,
does any one know where the "copy rotate" and "repeat lat command" functions are
located and how many layers down?
i will be gratefull if anyboby could enlighten me
they are such simple and effective routines i used since release 10 approx.
robert
melbourne
You do realise that revit isn't autocad???
Using the rotate command there is a check box for copy when rotating...
Get to know the shortcut keys and you'll find things much easier. Checkout your Keyboardshortcuts.txt file located in your revit program directory.
HTH.
repeat command shortcut key?? |
Tue, Aug 19, 2008 at 2:15:12 PM
Repeat Last command/Enter |
Fri, Oct 29, 2010 at 7:53:36 AM
Collaborate - Copy command changes type |
Fri, Nov 6, 2015 at 1:35:14 PM
Copy during Align command? |
Wed, Sep 5, 2007 at 5:05:22 PM
REPEAT COMMAND? |
Fri, Oct 31, 2008 at 10:01:42 AM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
