Forums >> Revit Building >> Technical Support >> Revit 2012 and Revit 2013 simultaneously?
May I install and have working simultaneously Revit Architecture 2012 and Revit Architecture 2013 without any problems between the two versions?
Anyone tried this?
Did you tried????
No, I hadn`t tried. I had a very important project but I want to try the new features of 2013 version these days. So I`m asking does anybody tried to have both installed and working properly?
Yes, I have both installed and working properly!
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Me too...
Edited on: Thu, May 3, 2012 at 8:05:06 PM
![itsmyalterego Avatar](user_avatar/109615.jpg)
I have both running at the moment. One is doing a walkthrough, minimized in the background, the other I'm drafting with.
I haven't installed 2013 on the other office computers or pushed people to upgrade their projects and get on the 2013 standard yet, because we unfortunately have 1/4 of our office on floating seats, and it's a hassle getting new network licenses from our distributor... and I'm lazy.
Edited on: Mon, Apr 30, 2012 at 5:58:00 PM
2 Posts No Rating |
hello guys,
I just wanted to ask if there is a way to create a project in revit 2013 and work on the same file in revit 2012 on a different computer.
In my experience REVIT files are not backwards compatable, so i would answer with NO.
2 Posts No Rating |
I think you are right.Thanks for the reply anyway...
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
David is correct, REVIT is NOT backward compatable.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
I have REVIT ARCH, Struct and MEP 2011, 2012, 2013 installed and working on the same PC. I don't actually use them all at the same time however but I do run some of them at the same time.
It is my understanding that REVIT does not and will not ever have backward compatible file formats. And it's not something I would ever wish for either. Backward compatibility = no forward progression. AutoCAD Architecture is a prime example of that. Dead in the water and grasping for air.
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Upgrading from revit 2012 to 2013 |
Tue, Apr 23, 2013 at 9:34:40 PM
Simultaneously drawing |
Mon, Apr 15, 2013 at 8:02:33 AM
Upgrading from revit 2010 to 2012 |
Thu, Oct 27, 2011 at 7:19:24 AM
Autodesk Revit 2013 |
Fri, Mar 15, 2013 at 3:17:15 PM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
