59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can't hide Curtain Grids
Fri, Apr 20, 2012 at 5:37:39 PM | Can't hide Curtain Grids
nmessmer
I am having an issue with horizontal grid lines on one face of a Curtain Wall Mass.  I am unable to hide green lines which identify as "Shared Levels and Grids: Curtain Systems: Curtain System: 2'-4 2/3" x 6'-8 mass"  which show up in all views aligned to this face.  If I hide this element or change the visibility settings for Curtain System, I am no longer able to see any mullions or glazing in the affected views.  Changing the visibility settings for Mass, Reference Lines, or Hidden Lines within Curtain Panels, Systems, or Mullions does not affect the problem.  I was unable to apply a view template to solve this problem, and unfortunately, the lines print, so I can't simply ignore them.
I'm attaching screenshots of a section view and a 3D, which should help illustrate the problem.
Any help would be much appreciated.
Thank you!
Nathan
Fri, Apr 20, 2012 at 5:58:53 PM | Can't hide Curtain Grids
nmessmer
Okay, for some reason, now when I turn off Curtain Systems in Visibility Graphics I am able to hide these lines without hiding the rest of the mullions / panels.  Not sure if this was something solved by rebooting...
Thanks.
curtain wall grids - deleting them
Thu, Mar 19, 2009 at 8:06:39 AM
Random Diagonal Curtain Grids in a Curtain Wall
Wed, Jul 6, 2011 at 6:57:03 AM
Revit sloped glazing & angled curtain grids problem
Thu, Feb 25, 2016 at 11:33:26 PM
11
non parallel curtain wall grids
Sat, Apr 28, 2007 at 12:54:05 AM
Butt-jointed curtain corner - no mullion?
Sun, Jun 28, 2009 at 8:15:44 AM
Page generation time: 0.6445
