39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Site Grading, Parking slabs and curbs
5 Posts No Rating |
I ahve a very large and relatively flat site where almost all of it will be asphlat for parking. I am just a tech drawing the dealership so I have to make it as to the specs of the dealership. I modeled the existing site with ease but I am running into problems when it comes to adding the parking with the new slopes and located catch basins.
I am using a separate file to model the site at the proper elevation and am referencing the 2 buildings into it. The largest problem I am having is with the asphalt and the curbs. I used a floor at level 0 and changed the points to the proper elevation so I could take proper spot elevations off it. I then added curbs to the edges via slab edges. Now that I am varying the heights of indvidual points to get drainage I am running into technical issues since revit thinks I am dumb for trying to do it this way.
Is there a better way to model 3d asphalt with my desired grading and a 150mm curb following that grade or am I better off just drawing this in AutoCad and call it a day.
Any advice is appreciated.
Thanks.
I am using revit 2012 but will likley upgrade to 2013 soon
I always split my topo surface and change the material to asphalt. There will be no thickness but I don't care here. I will add something in sections and details if deeded.
By splitting the surface, I can drop this whole topo portion the curb depth. This results in a gap between the two topo's since they have no thickness. No problem because I use walls for curbs. I can edit the curb (wall) profile if I have to adjust the top for topography slopes.
Extruded Curbs, sidewalks on grading |
Tue, Jul 4, 2006 at 2:15:41 PM
What's the best way to make a parking lot |
Mon, May 7, 2007 at 2:58:26 PM
curbs? |
Tue, Dec 7, 2004 at 5:17:58 PM
parking bays on sloping site |
Thu, Sep 29, 2005 at 9:08:43 AM
Site questions... |
Thu, Feb 19, 2009 at 12:31:11 PM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
