47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Beams not showing in floor plans but can see in 3D
Tue, Apr 17, 2012 at 9:12:09 AM | Beams not showing in floor plans but can see in 3D
bexgill2604
Hi -
I already had a model (9storeys) with walls and columns but now need to insert the beams for my structural drawings.
When I insert the beam on the floor plan it allows me to select the columns it will run between and acts as if it is placed and then I get this message " None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
Everything on the Visibility settings of the view is turned on so I dont know why I cant see them??
I want to label them also with the beam size but cant find them to click on to begin with.
Any help asap would be great!
Tue, Apr 17, 2012 at 10:02:08 AM | Beams not showing in floor plans but can see in 3D
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to check your view range iin the properties.  The beams are most likely set above your view range and that is why you are getting that message.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1469-2D_Views1469/1470-Plan_Vie1470/1475-View_Ran1475
Showing to steel beams in the same place on plans
Fri, Jun 14, 2013 at 11:36:26 AM
Mullions now showing on all plans?
Thu, Nov 29, 2012 at 9:46:32 AM
Beams not showing up in revit Architecture 2015
Tue, Sep 16, 2014 at 1:44:15 PM
plan callout showing up under Floor PLans in project browser
Thu, Apr 16, 2015 at 1:48:04 PM
Beams at different elevations in one plan
Mon, Nov 21, 2011 at 11:51:21 AM
Page generation time: 1.3491
