71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> revit arch 2013 my 3d views are transparent???..
63 Posts No Rating |
does anyone else find this problem with 2013? 3d views are transparent but only windows glass are visible through the model. thanks for help
I have the same problem and its a real bummer.
it ruins the perspective views.
i just found that when you enable photographic exposure in realistic view, the problem solved.
but that doesnt work in normal hidden view.
any more ideas?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27088
thanks typhoon - so does that mean that everyone using 2013 now has to disable the 3d graphics accelerator? if not how do you fix the problem?
cheers for your help
33 Posts No Rating |
After upgading the video card driver the problem was solved in our office.
20 Posts No Rating |
I know this thread is probably dead and burried now. However, I experienced similar issues and there was more one issue to resolve to get stop the 3D views looking transparent. For what it's worth:
1. I had to upgrade the graphic drivers for the new 2013 software.
2. With regards to 3D view templates; ensure that the tranparency slider is turned down to zero in the graphics display option of your 3D view style. In my case I was using 'SHADED' Refer image.
3d views are transparent in revit 2013 |
Tue, Apr 24, 2012 at 8:06:00 AM
any work around for this? transparent glass in shaded elevation views, revit 201 |
Mon, Jan 28, 2013 at 11:19:53 PM
Transparent object |
Tue, Sep 14, 2010 at 1:18:34 PM
Architectural Linked model transparent annotation in 2013 |
Tue, Apr 16, 2013 at 1:49:23 PM
Walkthrough showing semi transparent lines and surfaces!?? |
Thu, Aug 15, 2013 at 4:28:33 PM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
