83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> BUILDING APARTMENTS
Fri, Apr 13, 2012 at 11:24:13 PM | BUILDING APARTMENTS
a1214656
Hi,
Hoping to get some advice I'm building a mutli level apartment block with 8-10 apartments on each level I have made these outside of my main model and LINKED them back in. I now want to adjust individual apartment balconey, windows, enterence points etc. Is the only way to do this to BIND them to the main model? (each apartment is adding 10-15mb)
Sun, Apr 15, 2012 at 5:16:45 PM | BUILDING APARTMENTS
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
You should have 3 models
1 Site, context and streets (optional)
2 The department
3 The envelope.
You link all to the envelope, there you adjust all that you say need to be different.
Mon, Apr 16, 2012 at 7:08:52 AM | BUILDING APARTMENTS
3.5 Stars: 395 Votes
You can not edit a linked model while within the host model so you will hae to close the host to edit the links.
Do you have multiple links of the same model to get your 8-10 apartments or is each apartment unique?
If each unit is unique and is a seperate project with seperate sheets, the seperate models might be appropriate.  But if not, given the size of these models, I would have them all in my main model.  So I would bind them in.  Remember, when you bind, they become a group.  It might be appropriate to ungroup then delete the group definition.
Mon, Apr 16, 2012 at 7:35:35 AM | BUILDING APARTMENTS
a1214656
Thanks you for the advise and tips I'll try it now
Area Tag on Floor Plan
Fri, Mar 27, 2009 at 11:22:31 AM
multi building site with phases
Thu, Oct 25, 2012 at 10:35:27 AM
Optimize Topography
Sun, Oct 2, 2011 at 10:29:52 PM
Replicating floors and everythingon them
Fri, Apr 20, 2012 at 6:25:40 PM
How long to build a usable model by a good Revit user?
Mon, Jun 12, 2017 at 11:52:02 AM
Page generation time: 3.2929
