29 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Auto dimension And curtain Walls
Fri, Apr 13, 2012 at 9:20:31 AM | Auto dimension And curtain Walls
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I have a length of wall that has smaller curtain walls  inside it.  when i select auto dim and chose openings it only just graps the whole main wall.  if i use windows it selects and dims them just fime. is there a way auto dimi a curtain wall with in wall. or am i SOL.
Thanks
Tue, Apr 17, 2012 at 3:59:51 PM | Auto dimension And curtain Walls
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe you are out of luck.. how exactly do you have your curtain walls inside your wall and why dont you have them as actual windows?  If you are actually placing this inside of a wall you should be using a window.
Profile lines auto-associating with walls
Tue, Sep 28, 2010 at 8:32:12 AM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:48 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:34 AM
equal dimension curtain wall NOT SHOWING EQ
Thu, Dec 8, 2016 at 9:01:54 PM
custom curtain walls
Sat, Nov 1, 2008 at 10:49:39 AM
Page generation time: 2.9892
