52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Structural Steel problems
1 Posts No Rating |
Hi. I'm Chad and I am the Revit manager for SERA Architects in Portland Oregon. We do alot of work with steel sections used as architectural facade elements. However, the structural steel in 8.1has proved difficult for us to control. Ideally, we would have access to the Steel manual 2d profiles of various sections and use that to create architectural steel extrusions. Is there a way to do this? I could import ADT detailer profiles, but I was hoping to stay in Revit. Anybody had a similar problem? Any thoughts would help. Thx
If they are custom/curved then simply create profiles for each of the sections. Then use in-place families and create sweeps of the profiles to achieve what your after. If there are identical beams that need to be repeated, create them externally and load them in.
HTH.
How to Create Structural Steel in Revit MEP 09? |
Thu, Apr 2, 2009 at 2:08:56 PM
Roof to follow sloped structural steel |
Wed, Sep 22, 2010 at 4:11:16 AM
Can I change Structural member hatch scale, rotation?? |
Thu, Jan 26, 2012 at 6:18:18 AM
Sloping Structural Members |
Sun, Jan 9, 2005 at 5:32:40 PM
Structural steel label appearance |
Fri, Jul 28, 2017 at 7:47:51 AM
Members: | 2022559 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
