98 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> I need a help to create typ. Aluminum panel wall,
Thu, Apr 12, 2012 at 10:52:20 PM | I need a help to create typ. Aluminum panel wall,
Thread Post Kudo! #1
archuser01
i am been searchin almost 2-3 weeks and askin to my friends also, there is no really helpfull forum or videos that somebody did, but aluminum panel walls are really commanly applied to projects, no luck to find how to make custom wall that creates panels, it is really annoyin ,see the attached jpeg, so simple looks like but seems so hard in Revit...
help please
Fri, Apr 13, 2012 at 7:16:24 AM | I need a help to create typ. Aluminum panel wall,
If this is what you have, it is pretty simple.  If the panels are different colors in a pattern other than bands, that is harder.
We do these as simple walls and just add reveals for the joints placing them in elevation.  You can split the walls horizontally (either complete wall or just the face) to add different colors in bands as you show.
Fri, Apr 13, 2012 at 11:05:40 AM | I need a help to create typ. Aluminum panel wall,
archuser01
thanks for reply WWHub, but i wonder how to built like a real component , why becasue it could be counted to make estimation purposes, addin reveals is not really what i am lookin for.
Fri, Apr 13, 2012 at 2:44:36 PM | I need a help to create typ. Aluminum panel wall,
Most people would suggest curtain walls but they will not wrap the corners.  People doing precast walls use the curtain walls because they are only vetical.
Do you just want counts or do you also want size of each panel?  Either way, if you try to model this, your project may get real slow and you may pull a lot of hair.
I would model as I suggested, then I would use the following "trick".
  1. Create an invisible line family - face hosted - wall category with shared x-y parameters to reference planes that can be stretced to the size (instant) or type parameters.
  2. Create a label to tag this family.
  3. In elevations - apply these families with tags to each rectangle.  These could be arrayed where your pattern is a pattern.  Alternate corners to not duplicate.  Add "special" types for 'L' shaped or otherwise special panels.
  4. Now schedule these.
Fri, Apr 13, 2012 at 7:44:36 PM | I need a help to create typ. Aluminum panel wall,
archuser01
i am kind of fresly learning , i will be so appriciate if you can provide a liitle more specific or maybe any video /web links ,
Again thank you very much for your help.
Aluminum panel wall
Tue, Jul 6, 2010 at 10:02:21 AM
composite panel walls
Fri, Feb 25, 2011 at 1:32:37 PM
Needing to create a flowing wall panel system.
Sat, Feb 13, 2010 at 2:28:18 PM
Wall Panel System
Tue, Mar 24, 2009 at 10:31:06 AM
callouts with "typ" label?
Mon, Sep 15, 2008 at 1:44:41 PM
Page generation time: 19.9354
