59 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> creating window with glass area constraint
Wed, Apr 11, 2012 at 9:32:24 PM | creating window with controlled clear view area
paulettebalisi
Hi.  I am creating a basic window.  I have the width and height parameters.  But I need it to be controlled by glass area.  Can someone give me some ideas and let me know if this is posible?  The idea is for the window to have a width and height parameter with respect to its required maximum glazing area.  Thank you in advance!
Edited on: Wed, Apr 11, 2012 at 9:35:04 PM
Fri, Apr 20, 2012 at 3:58:45 PM | creating window with glass area constraint
designer619
This is possible, you can add a dimension to the edges of the glass (probably best to use reference planes to attach the glass to). add a parameter to the glass dimensions and add a locked dimension from the edge of the glass to the opening edge. See the image attached.
How do I Add an Area Parameter for Glass in a Window Family?
Thu, Jun 27, 2013 at 4:40:44 PM
glass plank wall
Sat, Sep 27, 2008 at 10:34:23 PM
Creating a glass stair
Tue, Oct 25, 2016 at 10:39:30 PM
Need help adding glass to a window I downloaded.
Wed, Sep 26, 2012 at 11:11:49 AM
Window Mullion Problem
Wed, Feb 24, 2010 at 3:56:34 PM
Page generation time: 1.3408
