90 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> Lighting Fixtures - being placed perpendicular to ceiling plane
8 Posts No Rating |
I have loaded about 20 different light fixtures into my project and all of them place perpinduclar to my ceiling, I am working on renderings and ceiling plans but obvously I cant have them attaching to the ceiling the wrong way. How can i fix this problem? I was able to get some recessed can lights to work by copy and pasting them from previous projects but with other light fixtures it still doesnt work.
Are you working in a reflected ceiling plan view?
8 Posts No Rating |
Yeah.
Then you should have no problem because you are looking at the bottom of the ceiling. Place your fixtures in RCP and look at them in 3D. You should have already tried this to see what happens.
8 Posts No Rating |
I tried - I've attached the 3D - view with different lights...
It appears that either you placed these from a different view or you changed your work plane.
Are these ceiling hosted elements or face based?
When placing them - look at your options bar to see if their are placement options.
8 Posts No Rating |
Thanks, it seems that I did somehow change the host and I don't know why I didn't notice that sooner - at least it was an easy fix.
Lighting fixtures at different heights |
Wed, Jul 15, 2015 at 11:17:29 AM
Why are my light fixtures on wrong side of the ceiling? |
Fri, Dec 13, 2013 at 9:38:09 AM
Lighting without ceiling |
Thu, Sep 10, 2009 at 11:02:50 AM
Revit 2011 - Light fixture family - XYZ plane issue (simple problem) |
Mon, Dec 27, 2010 at 5:38:29 PM
Specialty Ceiling Problems |
Tue, Nov 4, 2014 at 7:10:23 AM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
