88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevation's primary cut plane disappered and no grips
Mon, Apr 9, 2012 at 6:30:58 PM | Elevation's primary cut plane disappered and no grips
rlawson
Sorry if this was explained previously. I'm using Revit 2010.
When I select an elevation tag on the the floor plan, the primary cut plane (blue solid line with grips at ends) does not display. I can however see the dashed blue far clipping plane. Any ideas on how to display this line and its grips?
Tue, Apr 10, 2012 at 9:46:45 AM | Elevation's primary cut plane disappered and no grips
revitape
revitape Avatar
4.5 Stars: 9 Votes
Can't remember what things look like in 2010, but the solution should be to make sure "crop view" is selected for that view. See pic...
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Tue, Apr 10, 2012 at 10:43:09 AM | Elevation's primary cut plane disappered and no grips
rlawson
I'm afraid you misunderstood me. The solid blue line that cuts the elevation is not displayed. This line, that starts out near the tag placement, is dragable. Doing what you suggested will turn on/off the grips on that line (along with the dashed blue line on the sides); but you have to have the line displyed in the first place.
Tue, Apr 10, 2012 at 11:48:59 AM | Elevation's primary cut plane disappered and no grips
revitape
revitape Avatar
4.5 Stars: 9 Votes
Ah I did misunderstand you. Sorry about that.
I do remember having a problem like yours, but it was so long ago, I cannot remember the solution- if I even found one (might have just drawn a new elevation). I tried replicating your situation now but couldn't make that line disappear in the way yours did. Might be since I am in 2012 now... Sorry I can't help more!
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:17 PM
Elevation Cut Plane
Tue, Jul 9, 2013 at 3:46:47 PM
cut plane for stairway representation
Mon, Aug 14, 2006 at 6:02:35 PM
Issue with making a not primary option the primary Design Options Revit 9.0
Wed, Jun 4, 2008 at 5:52:15 PM
ELEVATION TAG CAN'T PRINT
Thu, Nov 9, 2006 at 12:21:50 PM
Page generation time: 1.0916
