55 Users Online (54 Members):
Forums >> Revit Structure >> Technical Support >> Revit Arch - Creating Integrated VERTICAL wall sweeps
3 Posts No Rating |
Hello RevitCity community,
I am trying to create a wall type for a shipping container with a vertical corrugated metal sweep integrated into the wall structure (family). (Edit type, structure, open preview, click sweeps and load a profile)
As seen in the first file, I have only been able to have an integrated sweep run horizontal.
I have gotten the profile to run vertical by using the wall sweep tool but when a window is inserted it cuts through the whole profile, unlike the integrated wall sweep where the profile is cut to the window.
I don't want this to work just because of the window but for ease of application and future knowledge.
I have searched and not been able to find any answers to this problem. If someone could direct me to help or figure it out I would really appreciate it.
Attached is the file I have tried to create the wall type in and the corrugated profile I used.
Thank you!
3 Posts No Rating |
The file with integrated sweep is to large.
Try adding the profile to a generic wall or post your e-mail and I will mail the file.
Edited on: Sun, Apr 8, 2012 at 4:36:54 PM
You can not define a vertical wall sweep in the wall definitions - only horizontal.
3 Posts No Rating |
Bummer.
Thanks.
i make a curtain wall that has the vertical sweep profile as the mullion
You could do this as a curtain panel with a nested and arrayed extrusion.
It's frustrating with getting the parameters to work. Here's a start. The corrugation of this family stretches with panel width and panel height. feel free to tweak this as needed. (it probably needs it.) to set materials, or edit the profile of the extrusions.
If you have any questions about my hack-job parameters, I'll monitor this thread.
Edited on: Tue, Apr 10, 2012 at 4:04:53 PM
Vertical Wall Sweeps |
Thu, Sep 13, 2012 at 7:52:24 AM
12
Creating a wall type with vertical sweeps/reveals/?? |
Tue, Apr 8, 2008 at 10:25:16 AM
Trimming sweeps |
Wed, Jan 25, 2006 at 3:50:55 PM
trying to mitre a horizontal wall drawn as an arch with a vertical wall |
Mon, Oct 18, 2010 at 6:44:52 PM
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
11
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
