73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Kohler toilet shows up as a cube?
Thu, Apr 5, 2012 at 10:45:22 PM | Kohler toilet shows up as a cube?
tavisc
Hi everyone. As the topic says, I'm having a problem with a Kohler toilet, in that it shows up as a cube, instead of the 3d toilet that it should be showing as. When I open it via double clicking, it shows up on a new sheet, and looks fine. However, if I place it in my model/drafting, it shows up as a cube. Any idea why this might be? Other toilets work fine (Caroma, standard toilets, etc,) but not this one. Ive really got no idea why its doing this. Please help? I'm on Architect 2012 as well.
Fri, Apr 6, 2012 at 4:18:10 PM | Kohler toilet shows up as a cube?
revitape
revitape Avatar
4.5 Stars: 9 Votes
Can you send a link if you downloaded it from somewhere?
The only thing I can think of is if there is a type catalog that goes with it. If that is the case you cannot import it from the family editor. You have to load it directly into your project and make sure it and the type catalog are located in the same folder.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Fri, Apr 6, 2012 at 5:35:40 PM | Kohler toilet shows up as a cube?
tavisc
I got it from here: http://www.us.kohler.com/tech/cadsymbol/symbols.jsp?module=All&type=3D%20Revit%20Families
Its the Numi toilet, near the bottom.
Fri, Apr 6, 2012 at 5:57:27 PM | Kohler toilet shows up as a cube?
revitape
revitape Avatar
4.5 Stars: 9 Votes
You're going to laugh at how easy this solution was... it's your detail level! See pic...
Sat, Apr 7, 2012 at 12:49:04 PM | Kohler toilet shows up as a cube?
tavisc
Thanks. I guess this is what I get for learning how to use Revit on my own :D
Sat, Apr 7, 2012 at 12:53:52 PM | Kohler toilet shows up as a cube?
revitape
revitape Avatar
4.5 Stars: 9 Votes
Ha no worries. One of those things that was so obvious I looked right over it myself at first.
Wed, May 8, 2013 at 2:50:26 AM | Kohler toilet shows up as a cube?
toddmk77
2 Stars: 2 Votes
Thankfully I came across this. I was wondering why a lot of the insert tubs were coming out as just blocks as well and I spent 3 hours trying to figure it out. At first I thought it was where I was getting the symbol from, then I tried to edit the component within the file itself and no such luck. The minute I changed over to fine, there was the all the detail I needed to see to make it look like a tub lol. Thank you for this!
Thu, Aug 29, 2013 at 1:15:06 AM | Kohler toilet shows up as a cube?
tronbon
Thank you for asking this question tavisc! But most of all thank revitape for your helpful and easy fix!!
I know you guys posted this 2 years ago, but it just saved my butt.
I've been having this problem as well and have spent hours of my youth trying to figure out these cubes...
Kohler toilet fixtures will not download
Thu, Mar 4, 2004 at 4:29:45 PM
kohler toilet inserting as elevation in floor plan
Wed, Sep 2, 2015 at 12:43:25 PM
KOHLER TUBS [ 1 2 ]
Sat, Oct 16, 2004 at 7:21:36 AM
15
Modeling a Toilet
Thu, Oct 1, 2009 at 4:40:05 PM
bathroom interior elevation
Wed, Apr 20, 2005 at 10:12:01 AM
Page generation time: 0.8163
