56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Filled Regions in Annotation Family not showing properly
Thu, Apr 5, 2012 at 5:23:51 PM | Filled Regions in Annotation Family not showing properly
Majlo
Majlo Avatar
Hi guys,
It's been a real pain in the curse today, trying to achive what it seem unachivable for now...
I want to have a room tag which uses filled region, two of them - one being black at the background, and one white in the front... so i get a "shadow effect". While in Family Editor it works fine (although there's no option of "bring to front" or similar... you can do a copy or draw a new one and it will be shown over tha last one...), it doesn't in the project.
Somehow the filled regions using solid fill (opaque by default) are being set transparent in the project environment.
I've tried with nesting, but you can only nest annotation family into annotation one...
strange...
I've attached the picture showing the problem.
Any suggestions?
Thank you.
Thu, Apr 5, 2012 at 7:07:59 PM | Filled Regions in Annotation Family not showing properly
revitape
revitape Avatar
4.5 Stars: 9 Votes
without delving too deeply into this, why don't you just make the filled region that represents your shadow the exact shape of your shadow instead of having it beneath the other shape?
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Mon, Apr 9, 2012 at 2:23:18 PM | Filled Regions in Annotation Family not showing properly
Majlo
Majlo Avatar
@Revitape: Well, that was my thought as well, but you know that revit has problems with very small sizes... In this case i.e., the shadow is around 0.5mm or less thick... It's just strange that the tag with filled regions acts like this...
Anybody?
Mon, Apr 9, 2012 at 3:03:36 PM | Filled Regions in Annotation Family not showing properly
revitape
revitape Avatar
4.5 Stars: 9 Votes
Well, at first I drew the shadow, then the white box on top of it.... got the same result as you.
So instead I just did that in reverse. White box, then shadow box on top. It looks bad in the family but looks right in the project.
Tue, Apr 10, 2012 at 2:04:24 AM | Filled Regions in Annotation Family not showing properly
Majlo
Majlo Avatar
Smile haha, great one! Another Revit bites the dust Smile Didn't think of that at all. It's strange that it works in this way, but it works. Thank you, much appriciated.
Greetings from Slovenia!  Milos
Tue, Apr 10, 2012 at 9:35:35 AM | Filled Regions in Annotation Family not showing properly
revitape
revitape Avatar
4.5 Stars: 9 Votes
Happy to help!
Sat, Jun 1, 2013 at 5:13:13 PM | Filled Regions in Annotation Family not showing properly
Gehrys
Back to this subject.
How would I get this box to have the drag arrows......like the island countertop family (i cant think of another family with this off the top of my head)?
Also, this would be great if it would work in a sheet.  Primarily on a Title Sheet where you might have some quick notes to add for the city reviewer. (you know, so he wont miss the info you already had in the drawings)
Filled region within detail family not showing in design option
Sun, Sep 21, 2014 at 7:24:46 PM
Door Display Issue & Annotation Filled Region Not Printing
Thu, Jul 12, 2007 at 9:55:56 AM
WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
Sun, Aug 3, 2008 at 1:51:22 PM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
annotation family with lines on top of a filled region
Wed, Mar 25, 2015 at 6:29:23 PM
Page generation time: 1.6552
