66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Material Takeoff for Demoed Walls
2 Posts No Rating |
Is there a way to do a material takeoff for walls that will be demoed. I have an existing masonry building and will be punching alot of new opening into the existing walls. I want to find the area of masonry that I will be demoing. Is a material takeoff the best way to do this or is there another way that makes more sense? Thank you in advanced for any help.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
I drew a masonry wall in existing, added three 36x48 windows in new construction, then made a new Material Takeoff Schedule. I added Area, Assembly Code, and Material:Area to the schedule. Then, in the schedule view, I changed the phase filter to "Show demo + New". This resulted in a schedule showing three items, each 12sf. Try that and then play with it to what you want it to look like. HTH
2 Posts No Rating |
Thank you for getting back quickly. I will try that.
Material takeoff: Walls appearing in wrong takeoff |
Wed, Sep 7, 2016 at 3:45:24 PM
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Sheathing Material Takeoff |
Mon, Apr 25, 2011 at 7:01:06 AM
Material Volume out of Material Takeoff |
Sat, Aug 9, 2008 at 7:23:48 AM
Material Takeoff walls/floors |
Mon, Apr 30, 2012 at 6:57:03 AM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
