Forums >> Revit Building >> Technical Support >> Actual VS Nominal
This may be a stupid question but it has come up a few times for me. When you are drawing a wall system that lets say is 5/8" gyp. both sides on 2X4 wood studs would you draw that wall as 4 3/4" actual thickness or 5". I know that standard practice is to draw it at 5" but then what do you do for you wall sections, details etc. since revit is actually building the model. I'm just looking for input on how others approach this. Thanks!
We always draw actual....2x4 is 4-1/2" Actual. I have been using CAD for 15+ years, and have never drawn a stud at a nominal size, so would disagree that drawing it nominal is "standard". When we dimension, it is to studs. If we measured to nominal, the guys building it in the field would scratch their heads if we called out the thickness of the wall as 4" (or 6" for a 2x6). In Revit, it is extremely important to draw it actual, as when you do details and blowups, you need the stud layer to be the correct thickness.
a 2x4 is 3 1/2" actual. i draw things actual. "model as you would build it".
Edited on: Thu, Apr 5, 2012 at 9:49:22 AM
couldn't agree more... actual is the way to go and model it like you would build it!
if you are going to have dimensions that aren't accurate to real life then you are just negating the power of BIM and Revit.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
Nominal Timber Lengths |
Thu, Oct 19, 2006 at 9:09:10 PM
Outside Diameter vs. Nominal Diameter |
Tue, Jul 29, 2014 at 8:30:34 PM
Need assistance building a reducing tee family in MEP 2011 |
Wed, Aug 18, 2010 at 4:33:45 PM
Reference View Tags not referencing actual detail number |
Tue, Sep 30, 2008 at 3:58:23 PM
Needed, Opinions on CMU wall widths |
Thu, Aug 29, 2013 at 3:43:00 PM
Members: | 2098909 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
