66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Multiple sheet with the same plan
Wed, Apr 4, 2012 at 11:26:20 AM | Multiple sheet with the same plan
sgray05
I am working on creating various sheets that would include the same floor plan. For instance I have an egress sheet and a finish plan and code compliance plan in addition to my basic floor plan.
Question is what is the best approach for creating these plans. Should I create a duplicate with detailing? and shall I put all my line work on the base floor plan or should it be seperated based on what I am useing the plan for..
Any direction would be of great help. Still trying to figure out the best way to "manage" all the views and layouts involved with creating a construction drawing set while also creating presentation sheets and such.
Thanks
Wed, Apr 4, 2012 at 12:18:41 PM | Multiple sheet with the same plan
Usually, you won't need any linework if working correctly so just duplicate the plan.  You may want to copy/paste, same place, some detail / annotation items like column dimensions / room tags but not everything.
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:14 AM
Multiple views on sheet
Tue, Oct 24, 2006 at 3:38:53 AM
Re-positioning a camera in plan when the view is already on a sheet?
Tue, Nov 20, 2012 at 12:48:10 PM
Placing Multiple Plans on Same Sheet
Thu, Jan 18, 2007 at 10:05:47 AM
Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Mon, Aug 29, 2011 at 7:58:13 AM
Page generation time: 1.2530
