26 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> RPC family problam
7 Posts No Rating |
Good morning,
in the middle of creating an RPC family, i realazed that the type parameter is almost empty. Besides the heigth there is nothing. It´s missing the render appearence parameter for exemplo. I try creating a new one and edit an existing rpc, but the result is the same.
The question is: can i add those parameters? and how?
thank you
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Check out this page in your Revit's help it may be useful.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034/2086-Plants_a2086/2092-Creating2092
7 Posts No Rating |
Teafoe5, unfortunately that web page wasn´t much help. But I finally discover what was the problem. I´m changing to Revit 2012, but during the installation all the metric families and templates were not install, so I used the Revit 2010 templates. Because that was what I used to work with. And that´s where the problem is. The metric family rpc 2010 does not work well in the 2012. So, my new problem now is to find the metric family and templates for the revit 2012. However, during this last days ever one points to go to the setup menu and there install the componets again. But that does not work, in the window where should be a list of components to reinstall its empty. Should I install instead the templates of revit 2011???
Rpc Creator made Rpc can't load |
Wed, Oct 24, 2012 at 5:12:32 PM
RPC PRoblems |
Thu, Nov 17, 2011 at 7:48:35 PM
Revit 2009 - RPC's |
Thu, Sep 9, 2010 at 3:16:34 PM
2009 RPC files |
Thu, Sep 9, 2010 at 2:47:12 PM
RPC and revit 2009 |
Mon, Jun 1, 2009 at 11:55:15 PM
Members: | 2025973 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
