50 Users Online (49 Members):
Forums >> Community >> Newbies >> No light inside building
15 Posts No Rating |
When I use the render-function the interior-pics are completley dark because there is no light except some from the window. How do I get light inside buildings?
Too many possibilities. Please read similar threads and search the forums. Then if you still have problems - give us enough information to help you. Pay attention to :
- Your light - does it really work?
- Is your light above the ceiling and there is no holes
- Is your light surround by a material that is not transparent
- Is your light turned on (and the sun off) and pay attention to intensity.
Read the treads and pay attention to them based on the above.
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Have you put lights inside your building would probably be a good place to start also.
"Have you put lights inside your building would probably be a good place to start also."
How do I do that?
You need to insert a lighting component into your ceiling. Click the "component" button and load a light fixture. Check out your help as WWHub stated to get a more detail about componets. There are also a lot of good tutorials that revit has for beginners, I recommend going through them.
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
Light Source in Revit - the dead horse |
Thu, May 6, 2021 at 4:34:17 PM
13
need HELP with creating a light shelf! |
Thu, Apr 19, 2007 at 7:15:59 AM
Tubular Skylight / Light Projection / Building Construction |
Thu, Nov 6, 2014 at 8:28:07 AM
Downlight with hidden light source |
Sat, Nov 23, 2013 at 8:19:33 AM
Members: | 2022537 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
