58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Typical Details
Sun, Mar 25, 2012 at 5:01:12 PM | Typical Details
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys just wondering how to show typical details (eave detail, Footing/Pad detail)
If I have a typical detail that I want to put in every job which is the best way I could do this?
Using symbol or something to put it in.I will want to show the cross referencing with the section to.
I was thinking do a call out of the section then hide everything and put a symbol in..Or is there a proper / better way to do this?
Thanks in advanced.
Revit 2018........
Sun, Mar 25, 2012 at 10:16:38 PM | Typical Details
PaulM3357
Import your typical detail in a drafting view (2d elements only). You can do this by using cut and past method or import a drafting view from another project by inserting view from another project file (look for it in the insert tab). Once you have set this up, you can use call out to to refence this view. The key to referencing a drafting view in a call out is to remember to toggle on "reference other view" in the option bar before you pick point to create the callout. Now you can pick a view from the drop down list in the option bar to link to your callout.
I hope this help.
Mon, Mar 26, 2012 at 12:16:59 AM | Typical Details
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks heaps I will give it a try...
Revit 2018........
Mon, Mar 26, 2012 at 10:12:57 AM | Typical Details
LIZARD2806
3.5 Stars: 7 Votes
If you have a large library of details, I recommend making them each their own family.  That way, you can drag and drop them into the project as needed.  If there are a number of details that are ALWAYS on your projects, you can inport the detail families into your default template and have them ready to go on a sheet.
**Using Revit Architecture 2009, 2011, and 2012**
Mon, Mar 26, 2012 at 10:27:51 AM | Typical Details
3.5 Stars: 395 Votes
Lizard - I disagree with you on this.  Details should never be families.   Detail components - yes but not details.  To edit the detail for a project would be cumbersome.
I suggest you keep your drafting details in a library, detail project.  We actually place them on a sheet in the library project so they can be easily viewed.  Then you can easily transfer single or multiple details from this project.  << Very fast.
Edited on: Mon, Mar 26, 2012 at 10:28:19 AM
Mon, Mar 26, 2012 at 10:35:41 AM | Typical Details
LIZARD2806
3.5 Stars: 7 Votes
WWHUB,
If they are details that never change,the ease of changing them will never be an issue and it is far easier than having to open a project and transfer project standards.  We do this for things such as a typical ridge vent, a typical footing, etc.  We also use it for manufacturer's details that we add to our sheet (which we SHOULDN'T be modifying).  Details that are project specific would not fall into this category, but Jamie351's question was for, "a typical detail that I want to put in every job".  So, in THIS SPECIFIC instance, I still hold this is the best option.
Mon, Mar 26, 2012 at 10:53:44 AM | Typical Details
coreed
coreed Avatar
4 Stars: 16 Votes
Proverb
to each his own
  1. Every person is entitled to his or her personal preferences and tastes.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Mar 26, 2012 at 10:57:07 AM | Typical Details
LIZARD2806
3.5 Stars: 7 Votes
very true.  Ans now Jamie can figure out HIS preference. Smile
Mon, Mar 26, 2012 at 4:55:56 PM | Typical Details
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Thanks heaps guys for all the input. I will definatly be refering back to this post. Thanks again much appreciated.
Revit 2018........
Custom Library - Typical Details
Fri, Jun 24, 2011 at 1:10:55 PM
Typical Details
Thu, Aug 28, 2014 at 7:54:38 AM
Typical details
Wed, Apr 14, 2010 at 1:11:59 PM
Typical Detail sheets on my first revit project
Mon, Feb 8, 2010 at 9:22:07 AM
Old Cad Typical Details
Mon, May 6, 2013 at 3:27:41 PM
Page generation time: 0.3283
