Forums >> Revit Building >> Technical Support >> family wont load
39 Posts No Rating |
i made a family for a block model of a site im doing but when i load it into a project nothing comes up. i cant understand what im doing wrong, can anyone help please
Check the following, if you haven;t already:
1. Zoom extents in a default 3D view to make sure it isn;t placed somewhere else.
2. If you don;t see it after #1, above. Click the light bulb to show hidden elements and zoom extents again.
3. If that doesn;t work, check your view properties (VV) to see if something is turned off.
i tried all of those and nothing works, i used load into project then tried to load family on the menu bar and it asked me about over writing it so its there somewhere but i still cant find it
Make sure you are looking in the correct category in the project browser. If you are unsure of the category, open the family and look in Family Categor and Parameters. It may not be set to what you think it is.
Go to the project browser, find it under families and drag and drop the family into your project.
Make sure you are putting on the appropriate workset if you are using worksets. if you are putting it on a workset that is turned off in that view, you won't see it. Turn on all worksets and see if it appears, move it to the right workset, and turn off the worksets you don't need.
It might also be that the family's category is turned off in that view. Check to see what the family's category is and make sure that category is visible in that view.
Open the family and make sure that it is visible in plan view or whatever view you are using in the project. If the family geometry is turned off in plan view, it won't show up in your plans, but it will still be in the project. Either turn the geometry on, or, better, leave it turned off and create a 2D symbolic representation of it in plan view using symbolic lines), which will be visible in project plan views.
Make sure that you are placing the family within the view range of the view. If it's outside the view range, it won't show.
Hope this helps.
jlights |
thanks for the help everyone, i finally got it working
the family mass wont load into my project |
Wed, Nov 10, 2010 at 1:46:28 PM
Cant figure out why Family wont load into project |
Thu, Jun 17, 2010 at 10:45:17 AM
Cant load families |
Tue, Jan 5, 2010 at 12:05:32 PM
Cannot load family |
Mon, Apr 18, 2011 at 5:22:02 PM
Reivt will not load door family |
Tue, Oct 11, 2011 at 7:23:13 AM
Members: | 2105459 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
