23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Parametric windows-width/height adjustable directly in plan
Mon, Dec 19, 2005 at 7:51:04 AM | Parametric windows-width/height adjustable directly in plan
ADSR
I am migrating from Autocad 2006 to revit.One of the advantages for me is that in revit you don't have to infinitely trim /strech wall lines when you move ,say,a door.But I have a question about windows.I need to be able to modify the window width(and maybe height) directly in plan or 3d(without opening the properties).Like modifying the wall length,you grab it from one end and....Is it posible to create a family of windows(doors) that have this degree of parametrization? I could not find the answer in revit's help. Thank you
Mon, Dec 19, 2005 at 12:15:10 PM | RE: Parametric windows-width/height adjustable directly in plan
Scott Davis
3.5 Stars: 3 Votes
Yes, if the parameters for width and height of the window are set to "instance" parameters, the windows will become stretchable in any view in Revit. But be aware that this could cause dimensions down to fractions of an inch, and all your windows will be completly separate instances and will schedule individually. Best to leave the parameters of the windows set to Type parameters, and just make new types from within your project set to real dimensions.
Whats the difference between rough width/height and width/height??
Mon, Aug 3, 2009 at 7:16:55 PM
Windows do not appear...
Mon, Jul 10, 2006 at 4:27:43 AM
Window family cut appears different in plan when height gets too small
Sun, Oct 22, 2017 at 7:31:11 PM
The same (one wall) to have varying thickness in its width dimension not height?
Thu, Mar 1, 2012 at 10:17:43 AM
Parametric Constraint Issue on CMU detail
Mon, Jun 18, 2012 at 4:08:55 PM
Page generation time: 1.5122
