57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Material Finish Pattern without using split face
Fri, Mar 16, 2012 at 12:02:44 PM | Material Finish Pattern without using split face
EnjoyRHCP
Hey all,
I'm trying to create a randomized metal panel material in Revit 2012.  I have attached a photo showing my intent.
Instead of creating quite a few split faces (which could be potentially tedious, ha) I was wondering if there is a way to do
this in an automated process.  I know I could make a bitmap image like the one below, but I'm also hoping to take it a step
further.  I'd like to have some control to make the contrast of the material lighten as it rises.  I've added a photo of the
Fluff Bakery (LTL Architects) to show what the intent there.
I supposed I could create around 3 bitmap images with variable levels of contrast, and create a simple wall and split the
face a few times, then apply the varied materials to each face?  Sounds like it could work? I'd appreciate any thoughts
you guys may have.  It also might sounds confusing so hit me with any questions too!
Thanks, and Happy St. Patty's Day Weekend!
Fri, Mar 16, 2012 at 12:13:11 PM | Material Finish Pattern without using split face
For these two images, one bitmap material would be the way to go.  Anything more random than that would be very hard to do except as you have already suggested.
Fri, Mar 16, 2012 at 1:18:45 PM | Material Finish Pattern without using split face
EnjoyRHCP
I ended up going with a bitmap, I haven't split the face yet and added a variation of materials yet, but here's what I have so far.
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 2:01:40 PM
split face CMU pattern
Wed, Jan 28, 2009 at 6:08:55 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:25 AM
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:27 PM
split face not remembering material - RAC 2008
Thu, Nov 20, 2008 at 3:13:32 PM
Page generation time: 2.0201
