40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> No Room colors?
Fri, Mar 16, 2012 at 11:22:13 AM | No Room colors?
erickson1026
Hello,
Working in Revit 2012.
I have come across a problem with Rooms.  While inserting rooms into the attached plan.  One room will not display the color.  Adjacent rooms work fine as you can see, but this one room even though it is assigned does not accept the color.
I have checked many settings but can't seem to work it out.
Thanks.
Fri, Mar 16, 2012 at 12:10:19 PM | No Room colors?
Sometimes .... you have problems like this when Revit is confused by overlapping rooms or multiple room dividing lines in the same place.
I have also seen problems like this with mirrored projects.
Room Colors don't show in R2010
Thu, Aug 13, 2009 at 11:38:20 AM
Different room with colors
Wed, Dec 20, 2023 at 12:02:22 AM
Painting Different colors per room
Tue, Feb 24, 2009 at 7:50:18 PM
Area plan not printing walls and doors below colors
Sat, Mar 14, 2015 at 1:26:37 PM
Room Schedule with Color Field
Thu, May 28, 2009 at 9:27:00 AM
Page generation time: 1.6229
