62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Multi Sloping Beam System
Fri, Mar 16, 2012 at 9:39:49 AM | Multi Sloping Beam System
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am trying to create a beam system where one end of the joists are at a constant height while sloping down to a beam (east-west) which is also sloping (north-south).. Is there a way to have the joists read all of the slopes and adjust accordingly?  I can get them to all slope one direction just fine using a reference plane but I cannot get them to individually adjust for the extra slope.  I basically want one end to sit on the wall at a constant elevation while the other end slopes.  The pic might not be the best examply but i think it gets the point across.  Hope I explained it ok!
Fri, Mar 16, 2012 at 9:48:18 AM | Multi Sloping Beam System
You mean you want the joist seat to slope at one end - not the joist correct?  You can't twist a joist.
Fri, Mar 16, 2012 at 9:54:45 AM | Multi Sloping Beam System
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I figured.  Thanks!
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:03 AM
sloping beam system?
Thu, Apr 20, 2006 at 4:56:37 PM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:21 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:11 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:34 AM
Page generation time: 0.5833
