99 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rotate surface pattern on a model-in-place blend
Thu, Mar 15, 2012 at 6:45:46 PM | Rotate surface pattern on a model-in-place blend
Reviteer0612
I've got a model-in-place blend for a ceiling that has a linear wood pattern on it.  For some reason my attempts to move/rotate the pattern produce no results.  Who wants to be my Revit hero?? ;-D
Fri, Mar 16, 2012 at 3:43:21 AM | Rotate surface pattern on a model-in-place blend
gebber
gebber Avatar
5 Stars: 4 Votes
Try to choose a new patern and take notice there are 2 kinds of paterns model and drafting.
My gues is jou used a drafting patern where jou should have used a model patern.
Fri, Mar 16, 2012 at 7:06:05 AM | Rotate surface pattern on a model-in-place blend
You will have to be in a view that is perpindicular to that surface.  I suggest that from a cross section view, you cut a horizontal section and rotate that so it is parallel to the surface.  Then from that view, you will be able to tab select your model pattern from an interior line and rotate it.
Fri, Mar 30, 2012 at 3:47:09 PM | Rotate surface pattern on a model-in-place blend
Reviteer0612
Thanks, WWHub -- that worked.  I am able to move and rotate the pattern lines, I just can't align them to edges of the blend.  Works well enough for me!
Aligning surface pattern on double-curved ceiling (in-place swept blend)
Mon, Jun 22, 2009 at 3:29:11 PM
Rotate Model Fill Patterns [ 1 2 ]
Sat, Nov 28, 2009 at 5:21:55 PM
15
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:21 AM
cannot rotate the reference plane of a swept blend
Tue, Feb 23, 2010 at 6:22:36 AM
SURFACE PATTERN ROTATION
Fri, Feb 5, 2010 at 1:27:47 PM
Page generation time: 1.0107
