70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cuts through Ramps in plan view
Sun, Dec 18, 2005 at 11:12:38 PM | Cuts through Ramps in plan view
wevit
Does anyone know if there is a way of making a plan view NOT show the cut through the entirety of a sloping slab and beams (Floor family). My plans are showing a multi-level carpark and the resulting cut through the floor in plan view (see attachment) is very confusing.
Mon, Dec 19, 2005 at 1:32:53 AM | RE: Cuts through Ramps in plan view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only solution would be to adjust the cut plane for this section using a plan region or adjust your overall view range settings so it doesn't cut the floor.
Mon, Dec 19, 2005 at 1:50:33 AM | RE: Cuts through Ramps in plan view
wevit
Unfortunately as the carpark is multilevel and the floor is a 'corkscrew' type structure the plan view HAS to cut through the floor somewhere - moving the cut plane will only shift the problem to somewhere else...... Is it possible to combine a partial plan view of one floor with a partial plan view of the floor below onto one sheet (so that it looks like a single plan view without showing a cut through floors) ?? Any other possible solutions? Post edited on 2005-12-19 01:51:09
Mon, Dec 19, 2005 at 1:59:21 AM | RE: Cuts through Ramps in plan view
eldados
eldados Avatar
4.5 Stars: 8 Votes
A plan region will be the best solution around the ramp, use it to minimize the amount cutting, than you might use a solid white region hatch and some drafting lines... HTH
Integrator
KarelCAD
Mon, Dec 19, 2005 at 2:33:11 AM | RE: Cuts through Ramps in plan view
wevit
Actually yes - the plan region tool is exactly what I'm looking for (I misunderstood Mr Spot's original answer). Thanks
Plan cuts incorrectly at windows despite correct view range
Thu, Aug 6, 2009 at 9:12:23 PM
Shadow problems with ramps
Fri, Jun 22, 2012 at 11:56:18 AM
Attach Walls to Ramps
Fri, Feb 18, 2011 at 6:45:16 AM
plan view cut plane inexplicably omits objects that it cuts.
Tue, Mar 3, 2009 at 3:54:46 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
Page generation time: 1.6349
