49 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> roof issue (even roof valley slopes with uncentered drain locations)
![paulykustomz Avatar](user_avatar/83612.jpg)
how can I use shape editing for a roof or floor to create a set of roof valleys that have even slope.
example I want the same position of the drains when moddeling but I want to just be able to tell revit to make all the slopes 2% for code purposes. I usually just calculate the heights manually for myself but ...somepeople in the office dont like this approach and find it to labour consuming.
is there a way>?
just so everyones clear revit arch 2012 x64
I wanna place the point using shape editing (not necessarily centered so define slope option is no good) , enter a slope value and have revit adjust the height.
Since your valleys go to the roof corners, it is physically impossible for all of these roof slopes to be 2%.
And there is no tool to do what you want.
thats what i thought thanks alot
flat roof internal drain |
Thu, Aug 24, 2006 at 5:17:27 PM
crickets for complex roof w/ multi slopes attached to beams |
Fri, Aug 1, 2008 at 3:13:45 PM
Roof Valley Angle |
Tue, Oct 4, 2011 at 10:06:05 AM
Adding skylights and slopes to a roof |
Thu, Jul 12, 2012 at 8:33:07 AM
Roof Drains |
Thu, Apr 9, 2009 at 4:08:44 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
