52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> corner boards
Sat, Dec 17, 2005 at 9:41:59 AM | corner boards
framerman
4 Stars: 13 Votes
My apologies, I'm a noob, I appreciate your patience. I'm trying to figure out how to place corner boards on the exterior walls. My search here revealed vertical sweeps. It's exactly what I'm looking for. However, I can only place the cornerboard on one side of the corner, the other side snaps 5�" away from the corner. I swear I've tried everything to correct this to no avail. I've even tried doing a mass object extruded which works, but I can't seem to figure out the visibility issue yet which I will eventually. Is the vertical sweep the way to do it? How do I get my "board" to the corner? Thanks again for your patience.
Sun, Dec 18, 2005 at 4:50:54 PM | RE: corner boards
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It would depend on your wall join. To place them both on the corner you would need it to be a mitre joint as opposed to a butt joint. Which you can change using the wall join tool. But, i'd probably make the profile as such that it wraps completely around the corner rather than having to place two sweeps to create the corner board.
REAL Corner boards
Thu, Oct 27, 2005 at 3:51:59 PM
Corner boards
Fri, Apr 21, 2006 at 11:38:12 PM
What is the best way to create corner boards?
Fri, Apr 13, 2007 at 3:34:11 PM
Skirting boards
Tue, Dec 15, 2015 at 3:36:54 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 1.3203
