46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how do you set a window back from the face of the wall of an exisitng window?
Tue, Mar 13, 2012 at 9:37:42 AM | how do you set a window back from the face of the wall of an exisitng window?
jsel13
i made this pretty complicated window and i realized it needs to set back from the face of the wall about 6" without totally destroying it, how can i add a parameter to make it do that?
thanks!
Tue, Mar 13, 2012 at 10:01:31 AM | how do you set a window back from the face of the wall of an exisitng window?
You need to plan ahead in Revit.  We start doors and windows by placing a reference plane in the family and building the family around that instead of the wall.  Then we add an instance or type parameter that moves this reference plane to a setback distance from the face of the wall.
Your problem is adding this plane after the fact is harder to do.  I suggest you add it well off the wall on the setback side...like 2'.  Then relocate your window elements accordingly so that they flex with the location of this plane.  Test the process often by moving the plane.  Then add your location parameter when finished.
Tue, Mar 13, 2012 at 10:17:50 AM | how do you set a window back from the face of the wall of an exisitng window?
jsel13
Thanks! i usually do plan ahead, but i forgot this time
what do i reference this new plane off of? the wall? or the centerline thats comes with the window family?
heres another question. i need to put an 8" reveal around the entire window.  the typical Wall/reveal command only lets you go horizontal and vertical.  how do i put it around the arch?  i have the profile, i just cant see a command to put it around the curved part? any idea?
Tue, Mar 13, 2012 at 10:37:00 AM | how do you set a window back from the face of the wall of an exisitng window?
You setback will be off the wall face ....I think that answers your question.  I build the element behind this plane so the setback is from the wall face to the face of the window which is usually how you would dimension that in the project.
window set back parameter
Wed, Apr 13, 2016 at 10:05:57 AM
window cant tell front from back
Wed, Jun 22, 2011 at 4:53:20 PM
Wall and Window problems please help
Tue, Jul 8, 2008 at 10:21:31 AM
Window Host Referance
Wed, Sep 23, 2009 at 12:53:04 PM
windows offset from face of wall
Fri, Jul 14, 2006 at 5:03:25 PM
Page generation time: 4.2110
