62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit to DWF walls missing
Sat, Dec 17, 2005 at 1:59:56 AM | Revit to DWF walls missing
jyothi
hi, i have converted Revit sheets to Dwf files, i see that some of the wall, lines etc inbetween are not too be seen in DWf file. Type, pattern and other properties of the wall, line are similar and are seen in Revit files. Waht may be the reason, can anyone suggest me regarding this. Thanks,
Sun, Dec 18, 2005 at 6:30:22 PM | RE: Revit to DWF walls missing
eldados
eldados Avatar
4.5 Stars: 8 Votes
what about when you print to PDF? do you see the walls? I will suggest to reinstall the DWF writer, could be that the driver is corrupt...
Integrator
KarelCAD
DWF Linking
Thu, Aug 23, 2007 at 12:55:33 PM
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:42 PM
Can anyone help me understand DWF's in Revit...Please?
Wed, Jun 21, 2006 at 1:22:47 PM
Does anyone have a Brick Arch Family?
Fri, Dec 4, 2009 at 6:42:37 AM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:12 AM
Page generation time: 2.4023
