57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RPC's won't render in 3DS Max after importing from Revit
Fri, Dec 16, 2005 at 11:22:15 PM | RPC's won't render in 3DS Max after importing from Revit
riksta
I'd like to animate a fully landscaped revit model in Max 8 and include RPC's from the Revit file i've imported into Max. The 'stick-figure' RPC geometry exports into Max but the photo element (which appears when rendered with Accurender in Revit) is missing. Does anyone know of an RPC plugin for 3DS Max or some other method of acheiving the same outcome ???
Sat, Dec 17, 2005 at 9:10:50 AM | RE: RPC's won't render in 3DS Max after importing from Revit
TomDorner
4.5 Stars: 25 Votes
If you RPC's are from Archvision ( www.archvision.com ) you will need a plug in from them to get them to work in 3DS Max. Even with the plug-in I'm not sure that they will be transferred over when you export out of Revit to a DWG. I'm still toying with the idea of using VIX/MAX and the approach I worked out was to get the building geometry done in Revit and then add the cameras, RPC's etc in ViZ/MAX. Tom
RPC and Camera's ??? --->>>Export to 3ds MAx
Tue, Oct 9, 2007 at 3:34:27 PM
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
3ds Max Design 2009??? importing from Revit 2009???
Thu, Feb 26, 2009 at 8:01:56 PM
Exporting RPC content from Revit 2014 to Max 2014
Tue, Aug 19, 2014 at 10:26:21 AM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
Page generation time: 2.1803
