80 Users Online (79 Members):
Forums >> General Discussion >> Revit Project Management >> rendering with linked files (high ram and takes longer than normal)
31 Posts No Rating |
I am currently trying to render a file (about 25mb) and when I hit render (on the lowest settings or higher setting) it takes about 10 minutes before moving from 0%. It also maxes out the ram on the computer. (Tried it on my laptop (12 GB ram with I-7 render took it to 11.8 GB) and on my desktop (16 GB ram with I-7 render took it to 15.4 GB ram). I am not new to Revit I have been using it for about 6 years now. I have had renders take forever but not like this. The only 2 things I can think of which I have not done before in Revit are rendering with linked files and using the beam system tool to make decking. I all so just found out about "use and-aliasing for 3d views" under options but I don’t see why this would make the render take longer. Please let me know if you need more information. Thank you for your time.
rendering problem |
Tue, Oct 14, 2008 at 7:25:46 AM
Quick rendering |
Sat, Nov 26, 2016 at 10:37:42 AM
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
Rendering Performance [ 1 2 ] |
Wed, Feb 15, 2012 at 6:14:36 AM
16
Rendering Takes up too much memory to run |
Fri, Aug 31, 2007 at 2:36:09 PM
Members: | 2022280 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
