Forums >> Revit Building >> Technical Support >> Multi-view Elevation - Reference SIM
Thu, Mar 8, 2012 at 5:10:58 PM | Multi-view Elevation - Reference SIM
nymn
nymn Avatar
(See attached)
I have a nurse's station with millwork on three sides. I have already placed an interior elevation tag which automatically created the elevation views. Since two of the opposing views are the same 'Opp. Hand' views they should actually both reference one drawing view and have a reference label, but I cannot figure out how to make them both reference the same view.
The only solution I could come up with was to hide the original elevation tag (which created the elevation views), and start a new interior elevation tag and check the 'reference other view' option. However, it appears that all four directions are 'reference other view' type and therefore I need to do all four directions this way. I can't delete the original because it deletes all my view sheets... so i've just had to hide it.
Is there a better way to do this that I overlooked? Thanks in advance.
~SG
Edited on: Thu, Mar 8, 2012 at 5:12:40 PM
Fri, Mar 9, 2012 at 8:28:34 AM | Multi-view Elevation - Reference SIM
Use the reference other view option.  This will be indepedent of your original elevation callout - not the checkbox.  Then since they will both have the same sheet number, just drag this over and drop on your other callout.
Fri, Mar 9, 2012 at 8:36:38 AM | Multi-view Elevation - Reference SIM
nymn
nymn Avatar
Ok I follow you, no need to re-reference all the other views, just the Opp Hand one and hide its sheet reference then slide it over the original. That makes sense. Thanks for the reply.
Fri, Mar 9, 2012 at 8:40:42 AM | Multi-view Elevation - Reference SIM
No need to hide the sheet number because it will be the same ....
Callouts and Callout Sim Views
Thu, Sep 12, 2013 at 10:41:57 AM
Sim location issue on Elevation tag
Wed, Nov 5, 2008 at 11:50:16 AM
Interior Elevation Reference Label
Fri, Jun 18, 2010 at 2:58:09 PM
elevation SIM
Wed, Jan 26, 2011 at 1:28:29 PM
Re-referencing Elevation Tags - Revit Architecture 2008
Tue, Aug 14, 2007 at 8:47:36 AM
Page generation time: 1.1815
