26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Title Block struggle - labels changing in all sheets
Hello,
I´ve been struggling with my titleblock for awhile now but i´m not giving up to AutoCad again, I´ll take the whole process with Revit this time...
The thing is: When I finally figured out how to create new labels for my titleblock I had a big smile on my face, but that disappeared as soon as I created a new sheet and found out that in this new sheet all of the new labels I´ve created were unable to be changed one by one, if I change one label on the 1st sheet for e.g. it will change all the subsequently sheets...
All I need is a little spot where I can write whatever I want (without having to create one title block family for each sheet I use, as I´m about to if I can´t figure out how to do this), if you guys have any hints it´ll definetely be very handy for me!
You know how you can just click on the sheet number label and it´ll pop up a space for you to type whatever number you want? That´s what I need but I created a label that if I change one time it´ll change in all sheets.
Thanks a lot,
PS: I use Revit 2011
You need to spend some time learning about instance and type variables. Download the families guide from the autodesk site and work your way through all of that. You will not regret it.
Thanks for your reply, I will do that! I know there are bunch of things I´m missing on revit still but i´ll make my way through it.
But... if anyone would like to take a look of what I´m doing wrong, I´m posting my title block. Thanks again
Title Block labels |
Sun, Apr 8, 2007 at 10:04:03 PM
Title Block Labels |
Wed, Feb 14, 2007 at 11:52:49 AM
Title Labels [ 1 2 ] |
Sat, Jun 29, 2013 at 12:54:18 PM
16
Labels in title block literally gone in project |
Thu, Nov 20, 2014 at 8:22:22 AM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
Members: | 2017920 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
