101 Users Online (99 Members):
Forums >> General Discussion >> Revit Project Management >> Errors regarding dimensions when opening
9 Posts No Rating |
Hey everyone, first time poster here. One of my Revit users is getting an error every time they open the project relating to dimensions. The project is a legacy hospital building with 90% of the geometry done in CAD and a 10% in Revit. I'm assuming that the problem is the user is dimensioning from a CAD element to a Revit element which will need to be done through the life of the project. But every time they open the project the only choice is to delete the dim's or to not open the file.
Anyone know a work around for this? The only thing I can come up with (haven't tested it yet) is to put a piece of line work in Revit and dim from Revit element to Revit element. This seems rather cumbersome ant not very Revit like.
Error report attached.............
Any help would be appreciated,
Mike Adams
The report didn't attach
9 Posts No Rating |
Hmmm............try this
Error Report (3/6/2012 8:58:28 AM)
Error messageElements
One or more dimension references are or have become invalid.
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318136
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318150
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318157
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318249
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318256
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318370
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318395
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318402
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318462
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318469
Workset1 : Constraints : Linear Dimension Style : id 1318476
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318577
View "Floor Plan: H3 (BASEMENT)" : Dimensions : Linear Dimension Style : TGB - 3/32" Arial : id 1318596
9 Posts No Rating |
OK....so that came across un readable, I'll try a PDF print of the HTM file.
Are these CAD files linked? If so, could this be a problem with the pathing of the link?
Is this user on a different operating system? We have seen pathing problems from this.
9 Posts No Rating |
Yes they are AutoCAD files referenced in the model, but I don't believe pathing should be an issue as they are located in a network environment and not a local one and everyone is on the same OS. I think I figured out that if you dim to a linked CAD file Revit reloaded on opening and treats it as a "new" object so the dim's lose their association. I guess if we need to dim to a CAD location I will have them draw a detail line in the location, this way it won't lose the association......hopefully.
Thanks for the help,
Mike
We have seen Revit issues with mapped drives vs UNC mapping. We do not fully understand the problem but even on the same network using the same operating system can have problems.
9 Posts No Rating |
Hmm.....have you figured out and "fixes" for this particular issue other than inserting the CAD file?
Center an opening in the wall |
Sun, Jul 26, 2009 at 6:36:13 PM
Assembly Schedule - structural opening |
Sat, May 12, 2012 at 2:57:25 AM
dimensions missing after exporting to ACAD |
Mon, Jan 5, 2009 at 3:18:52 PM
Errors and warnings crashing out of Revit. |
Fri, Nov 10, 2006 at 1:41:53 AM
Scheduling Shaft openings indicating its clear dimensions |
Tue, Jan 19, 2010 at 2:17:12 AM
Members: | 2030703 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
