74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> revit arch rendering on multiple computers
Mon, Mar 5, 2012 at 10:20:44 AM | revit arch rendering on multiple computers
jesus3boy
sorry if this is the wrong place to ask this. I was wondering if there is a way to render one image using multiple computers over network in revit 2012.
I have a desktop and a laptop and my laptop doesn't suck too bad so it would be nece if it could help out my desktop with rendering.
I have a new gigabit switch to plug them both into as well.
is this possible?
Mon, Mar 5, 2012 at 11:46:16 AM | revit arch rendering on multiple computers
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have not heard of rendering a still image across multiple PCs but would be interested in the process if possible.
You can however spread out a rendered video walkthrough output by splitting up the frames.
Mon, Mar 5, 2012 at 2:06:47 PM | revit arch rendering on multiple computers
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
revit does not have backburner support. a work around would be to duplicate your 3d view and set one to render the upper region and the other to render the lower region. then combine to the two images in photoshop.
Mon, Mar 5, 2012 at 2:25:11 PM | revit arch rendering on multiple computers
LIZARD2806
3.5 Stars: 7 Votes
Assuming you are looking for faster rendering via more computing power; I have not tried it, but Autodesk subscription members can download and use Project Neon which will render via Autodesk's "Cloud".  Presumably this would be faster.  I seem to recall reading somewhere about some limitations of it, but again, I haven't tried it.  HTH
Mon, Mar 5, 2012 at 2:33:30 PM | revit arch rendering on multiple computers
alabaster2513
3.5 Stars: 25 Votes
Neon is ok but if you are using photometric lighting you have really no options on adjusting anything. it does ok for daylight scenes, very fast.
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:19 AM
Need a brick arch for rendering. Any suggestions or sources?
Wed, Jan 22, 2014 at 5:35:29 AM
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:56 PM
rotate rendering
Fri, Jun 2, 2006 at 4:39:24 AM
Problem Rendering Sketch-up Components in Revit Arch 2009
Tue, Dec 9, 2008 at 1:08:37 PM
Page generation time: 2.6575
