130 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Arch Top Window Header
Mon, Mar 5, 2012 at 10:05:48 AM | Arch Top Window Header
christofur84
4.5 Stars: 5 Votes
I have been searching window companies for an arch top casement window but have had no luck.  Revit content has a casement window with mullions numbers already made.  I decided to modify this family into an archtop casement.  I have it working 90% other than a header callout issue.  I can get a formula to reflect the actual header height but cannot get the default header height to change.  Is there anyway to modify iether the text of the default header height or create a formula for it to reflect the correct header height to the top of the spring on the window schedule?
@berriosdesigns
Mon, Mar 5, 2012 at 3:43:08 PM | Arch Top Window Header
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not 100% sure on this but I think you would need to delete the default header height parameter and redo it the same way, making the new "default header height" to the specificatinos you want.
Window - Arch top outside - rectangle inside
Thu, Mar 22, 2007 at 10:25:00 PM
concrete window sill and header category?
Mon, Mar 10, 2014 at 7:24:06 PM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:23 AM
Creating a new window family. How do I re-shape the opening in the wall?
Mon, Jan 10, 2005 at 1:18:44 AM
Need help with window?
Tue, Nov 24, 2009 at 1:38:33 PM
Page generation time: 1.6877
