82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> PRINT - different paper sizes (with 1 click)
90 Posts No Rating |
How to print the entire project with different paper sizes?
In Autocad we use the PUBLISH tool, in Revit we use .......
Do you wanna SKYPE Revit? Its quicker ![Smile](/images/smiles/smile.gif) |
Sorry, but you question is not clear. Unlike AutoCAD, Revit has an extensive HELP so I suggest you start there.
Print
The Print tool prints the current window, a visible portion of the current window, or selected views and sheets. You can send the desired drawings to the printer, to a PRN or PLT file, or to a PDF file.
Printed output in Revit Architecture is What You See Is What You Get (WYSIWYG), with a few exceptions:
OK ![Smile](/images/smiles/smile.gif)
Imagine you have 3 different paper sizes in a project with 20 sheets.
How can you print all sheets at once to individual PDFs?
When we do that, revit uses one paper size for all sheets.
How can you have Revit to pick the right paper size to each sheet?
Any tips?
Thanks in advance!
Edited on: Mon, Mar 5, 2012 at 7:40:03 AM
http://www.xrev.com.au/
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
What about the free REVIT 2012 Batch Plotting Extension ? Haven't tried it out myself but sounds promising.
Batch Print for Autodesk Revit 2012
Batch Print provides an easy way to print a large number of drawings (views and sheets) from a Autodesk® Revit® Architecture 2012, Autodesk® Revit® Structure 2012, or Autodesk® Revit® MEP 2012 software project. After preparing the default printer and the Revit software project, use Batch Print to send any number of drawings to the printer and to control the order in which they print. When you start the print job, Batch Print manages the printing of the drawings, requiring no further interaction from you. If desired, you can monitor the progress of the print job using a status dialog.
print combined file, but with different sheet sizes |
Sat, May 6, 2017 at 5:22:19 PM
crop option for printing in sheet |
Tue, Apr 1, 2008 at 4:57:41 PM
Print entire projekt to single pdf files |
Mon, Sep 6, 2010 at 7:58:08 PM
text sizes |
Fri, Jan 31, 2014 at 3:25:52 PM
Revit printing on incorrect paper size |
Mon, Jul 4, 2011 at 10:05:37 AM
Members: | 2017008 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
