68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mapping faces
Sun, Mar 4, 2012 at 11:31:02 PM | Mapping faces
brjdk
Hi I'm trying to figure out how to adjust textures on single faces. I would like to be able to move, scale and rotate textures, but I simply can't find where to do it. Is it actually possible? Thanks
Mon, Mar 5, 2012 at 2:59:18 AM | Mapping faces
brjdk
I'm asking this, because I would like the wood to be aligned like shown in the attached image.
I hope someone know how to change the alignment.
Thanks
Mon, Mar 5, 2012 at 7:51:36 AM | Mapping faces
From your HELP:
Texture Alignment
Use the Texture Alignment tool to align the texture of the render appearance to the surface pattern of the material (defined on the Graphics tab of the Materials dialog). When you render a 3D view, the rendered image displays the texture, positioned as specified using the Texture Alignment tool.
Topics in this section
AND
Aligning the Surface Pattern on a Model Element
To align a surface pattern on a model element
  1. Open a project view that displays the model element with the surface pattern to align.
    To specify a surface pattern for the material of the model element, see Changing the Display Properties of a Material. If the surface pattern does not display in the view, you may need to change the view’s detail level to fine, or zoom in on the model element.
  2. Place the cursor over a line of the surface pattern.
  3. Press TAB one or more times until the surface pattern line highlights.
  4. Click to select the surface pattern line.
  5. Move the selected surface pattern line as desired, using one or more of the following techniques:
    • Press the arrow keys to nudge the surface pattern up, down, left, or right, in small increments.
    • Use the Move tool to move it a specified distance. See Moving Elements with the Move Tool.
    • Use the Rotate tool to rotate the surface pattern. See Rotating Elements.
    • Use the Align tool to select a model reference with which to align the surface.
Mon, Mar 5, 2012 at 1:55:20 PM | Mapping faces
brjdk
Hi wwhub
I'm sure doing someting wrong.
I create a mass, add a texture, select a texture line and tries to rotate it. But it's the mass face that rotate, not the texture :-(
Make pattern&mapping bend
Wed, Oct 30, 2013 at 9:06:10 AM
Picking multiple faces when creating walls
Fri, May 6, 2011 at 2:12:40 PM
Mapping Images
Sat, Nov 17, 2007 at 5:20:30 PM
Mapping Images
Thu, Nov 15, 2007 at 4:39:31 PM
Revit 2017 weird mapping in shape-modified floors
Thu, May 11, 2017 at 11:56:49 PM
Page generation time: 0.8269
