49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> The same (one wall) to have varying thickness in its width dimension not height?
Thu, Mar 1, 2012 at 8:12:51 AM | The same (one wall) to have varying thickness in its width dimension not height?
mikeyos
I have been looking for tutorials every where to find the answer but i cant...
can some one please explain to me how i can make one wall have varying thickness...i dont mean in stacked walls on top of each other but a wall to be thick on right side and thin on the left in its width. i have been tracing this autocad plan to make a model from it and revit seem to only have striaght walls with no adjustable varying thickness in one wall.
i have tried using 2 to 3 saparate walls to give one wall varying thicknes but it doesn't look professional.
Thu, Mar 1, 2012 at 8:44:15 AM | The same (one wall) to have varying thickness in its width dimension not height?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Does this wall happen in a lot of locations?  you could use an in-place mass and add a wall type to the face.
Thu, Mar 1, 2012 at 9:07:38 AM | The same (one wall) to have varying thickness in its width dimension not height?
TKennedy
4 Stars: 7 Votes
I would try three different wall types (you should be able to construct them so they all join and look the way you want), or make an in-place wall.
Thu, Mar 1, 2012 at 10:03:18 AM | The same (one wall) to have varying thickness in its width dimension not height?
mikeyos
Tkennedy i am doin it like how you menstioned and the different type of walls are connecting but i thought i could
to it in an efficent way....anyways
and teafoe5 there are quiet a few walls with this type of walls.
i will try in-place but i cant find any tutorials for my situation
Thu, Mar 1, 2012 at 10:17:43 AM | The same (one wall) to have varying thickness in its width dimension not height?
mikeyos
Tkennedy I figured it out i think...i think the best way to do it is by in-place mass and then assign wall thanks..it looks better already
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Spot Elevations on curved walls with varying height
Tue, May 3, 2011 at 5:26:46 AM
Whats the difference between rough width/height and width/height??
Mon, Aug 3, 2009 at 7:16:55 PM
Changing wall thickness issue
Thu, Oct 12, 2006 at 11:07:14 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 1.1378
