93 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Attaching beams using "Beam/Column Joins"
Wed, Feb 29, 2012 at 9:07:11 PM | Attaching beams using "Beam/Column Joins"
stephensbrt1993
I'm working on a building right now that has steel channels, drip edge, and L-angles within close proximity (inches apart). For some reason, every time I go to join a pair of like beams together at a corner it affects the others. For example, I attach the channels so that it is mitered and lock it. Then I go to attach the drip edge the same way and it unlocks the channels and doesn't give me an option to reattach them. It gets even worse when I add in the third beam, the L-angle. Any suggestions?
Structural Beams Questions
Sat, Sep 8, 2007 at 1:48:34 AM
Hip Beam/Column
Tue, Aug 18, 2009 at 6:24:18 PM
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:45 PM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:42 PM
Beam Joins and Columns
Fri, Jul 22, 2011 at 3:06:50 PM
Page generation time: 0.9606
