Forums >> Revit Building >> Technical Support >> Outlets and Wall Sweeps
6 Posts No Rating |
My firm uses wall sweeps to designate tiles on a wall, think bathroom or kitchen wall tiles, and I need to place the electrical outlets on the interior elevations. Unfortunately, the outlets get hid behind the wall sweeps since that are wall hosted. I cannot simply make the sweep transparent since it is a CMU wall with pattern behind the sweep. Any ideas of how to make the outlets show?
thanks.
Are you outlets wall hosted I assume? If that family was built (or modified) with a face offset, that would work. Another possibility is not to use a sweep for the tile but a thin wall and host the outlet on that. And finally, a split face material instead of the sweep would work.
We like to use thin walls for all partial height tile walls (finishes).
6 Posts No Rating |
They are host based. And I am in no position to change the wall sweep, I am just helping on the project for today and tomorrow, then back to my project. I may try the offset approach, maybe just make an instance parameter for tile or no tile.
6 Posts No Rating |
Instance parameter for an offset worked like a charm. Thanks WWhub.
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Switches - electrical plans |
Thu, Jan 6, 2005 at 2:44:09 PM
Wall sweeps line weight |
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps |
Sun, Jul 12, 2009 at 1:54:07 PM
13
Members: | 2099020 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
