41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> 3D PDF inclusive material textures
Wed, Feb 29, 2012 at 7:57:55 AM | 3D PDF inclusive material textures
Kbtrpnis
Hello all,
I'm trying to create a 3d PDF file from a Revit building. I'm using Bentley I-model plug-inn and the Bentley I viewer. I get a nice 3D pdf, but only with some basic colors. Is there a way to create one with more detailed materials or textures?
Thu, Mar 1, 2012 at 12:56:08 PM | 3D PDF inclusive material textures
mschell
I have tried the PDF revit from Tetra 4D and it will give you the textures! You can also choose to not have textures if you are doing a quick model. I suggest to check out thier facebook site and download the trial. works well and they just announced the release for Monday the 5th. 2012. Check it out!
http://www.facebook.com/3DPDF#!/3DPDF?sk=app_153284594738391
www.tetra4d.com
Mike
Mon, Mar 5, 2012 at 1:12:38 AM | 3D PDF inclusive material textures
Kbtrpnis
Thanks for your reaction.
I tried Tetra trial version, but the Revit pluginn doesn't work. I can try to re-install it.
Anyone an other solution to get textures in a 3D pdf?
Mon, Sep 24, 2012 at 4:05:06 AM | 3D PDF inclusive material textures
IoanIancu
2.5 Stars: 2 Votes
scrapbooking
Mon, Jun 24, 2013 at 12:58:17 PM | 3D PDF inclusive material textures
hbaker4d
Tetra 4d has recently released the new version of 3D PDF for Revit 2014 which includes updates for more realistic textures and materials. You can create 3D PDFs directly from the Revit Add-Ins menu, where you can accurately export all 3D model elements including structure, color and texture to 3D PDF. Hope this helps!
Hayley
Tue, Jun 25, 2013 at 2:28:05 PM | 3D PDF inclusive material textures
mschell
Try 3D PDF Converter for Revit from 3DA Systems. The software handles and supports textures from Revit 2012/2013/2014.
http://www.3dasystems.com/products/3d-pdf-converter-revit/why-3d-pdf/
or Autodesk Exchange Store:
http://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3a3dpdfconverterforrevit14%3aen
30 Day trial avaliable.
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:16 AM
Printing PDF Line Drawing - Wont show surface textures
Tue, Oct 23, 2012 at 9:24:40 AM
Revit 2013 textures not printing to pdf or paper
Mon, Feb 3, 2014 at 2:15:53 PM
how do I fix a material
Tue, Apr 15, 2008 at 10:47:26 AM
free hi res textures
Mon, Apr 13, 2009 at 2:47:30 AM
Page generation time: 0.4840
